A
allenmac
Guest
Has anyone tried the Droid X keyboard on the Dinc??
you guys have the apk for it?
You have to be rooted for that to work? There is no other way?
why are the letters so friggin small? is there a better version of this anywhere?
Are you using it on MIUI?
i am... does that matter? i mean i dont really care but it would prefer ones i didnt need retina display to see
Well the issue now for this is, the font is small on MIUI. It should work alright on other roms.
those two apk's don't work on mine. when i install, it says "application not installed" at the end. any ideas?
You do not have to be rooted. It is running on mine.I am almost certain that you have to be rooted to get this keyboard on your Incredible, because you have to remove your original keyboard apks (latinIME or whatever) before installing this one
