Help droid x rollback to 2.3.3?
Ah man that sucks... im havin problems with the camera when i take pictures and there blank.. the phone restarts by it self alot of times.. and akso alot apps force close.. and it just seems really slow.. and the also battery life.. i cant stand it.. is there anything else i can do. To like make it better.. maybe install a new rom. Idk.but im just sick of it ..
I've seen other posts mention that this may be related to a bad SD card. Do you have another one you can swap in to check?
If i try factory reset. Would it go back to 2.3.3? And yes i have another sd card. I will try t.. the reason i eant 2.3.3 back is so i can root it and get rid of all the crap. I heard and also tried to root 2.3.4 and it dooes not work
All our DXs(2) and DX2s(2) have problems with the camera after .621. Simply restarting the phone makes it work but that is a pain to if the problem crops up a lot. Mine goes thru spells where it works just fine, then every other time I open the camera it messes up.
