Root Droid X ROM
The widgets you want are Ninja Blur widgets, and most likely cannot be used without having the Ninja Blur gui. Just like sense widgets can only be used on sense android.
Only thing i want from the droid X is for the multi-touch keyboard to be ported to 2.2.
well they might not be useful in your opinion but maybe some people like myself would love to have them
Like the guy above me posted. Those widgets that you want, (and they look ok to me, I like the ones I have, but to each his own.) Those come on NinjaBlur, That is a Motorola's version on Sense. I dont think that is going to happen, But good luck in trying to find them!!!!
is anyone working on porting the droid x ROM to the incredible?
Check this thread . It's not the launcher/widgets/icons etc, but it's got the notification bar, font, dialer, and lock screen. It's a really slick look on the Incredible with Launcherpro.
Edit: I exited LauncherPro and noticed that this does change the launch bar at the bottom. Doesn't effect the app drawer.
Edit Edit: Because I'm and idiot and forgot the link: http://androidforums.com/roms-incre...d-x-notification-bar-framework-detox-xda.html
