Help Droid X screen hugh and brightness different
Doctorsti
I have two X's now in front of me. My old one is in airplane mode so it's not confusing Verizon but the replacement phone looks way more dim on "auto" and when you push them to full brightness the replacement phone is slightly dimmer and definitely more blue in color. There is a blue hugh to the replacement phone. Anyone else have the chance to compare two phones like this side to side?
I just can't catch a break.
Here's a link that might help. For the record, mine looks more like the one on the left as did the ones I saw in the verizon stores. A CSR told me that the different screen hues was a known software issue. However, while the difference look pretty obvious side-by-side, I think it's pretty hard to tell when you're looking at the phones individually. For example, when I saw the store phone screen, I couldn't tell if the hue on it was different than mine (it wasn't) until I put it next to my droid x.
If it really bothers you that much than you can switch it for a new one. They were willing to do that for me. I chose not to since it doesn't bother me that much. Movies still look great on it. Besides, there was no guarantee that the replacement would be any different.
I think it's pretty common. I've seen posts like this on many different phones. Generally you would never know unless you have two side by side. Apparently it's not easy to make them all identical.
