Root droid x system update pop up help please :.(
vibe909
i have a droid x flashed ot metro pcs i did not flash it or root it myself i paid someone to do it i was messing with the fone and now all of a sudden the 2.2 or 2.3 system update im not sure witch tho it keeps popping up and i keep pressing later but i heard i cant update my fone cuz it will take the flash off and the root.. its getting kind of annoyingg clicking update later wat should i do someone help please!!!!:(:(:(:(
Moving this to the "root" section. :D
You'll have to be rooted to stop the update.
You'll need to see what your kernel version is (settings... about phone) so we know how to proceed, but if you're not on GB (white status bar), you'll need to root with z4root and rename a file to prevent the update from running any more.
O/W, you could take the update and have your phone modded again.
Otherwise there is a setting (under settings), which is for social networks and says to "update over wifi only" and will disable the update. Unfortunately I'm on a custom rom and don't see that on my X.
ok sory im all late thanks for the help but i solved the problem . but i was wondering scince i have my droid x fully flashed to metro pcs already but its not rooted and i wana root it how do i do it or is it even posssible? im running android 2.3.3 . thanks for the help get back to me ASAP thhnaks : D
