I recently got a Droid X and I was trying to use the tethering using PdaNet and it works fine then I get the blue screen of death. I need to run the Pda install again and it works fine for a while. Any suggestions?
<bump!>
Hi,
I'm new here and pleased to meet you all.
I just got a Droid X too, and am having the very same problem.
Like RoadHawg, PdaNet runs fine for a random amount of time, then I get the blue screen saying the stop point is pneteth.sys.
I'll contact the company directly, and will post my experience here.
I do not want to root my phone, and my phone is my only web connection, so I would be hugely grateful for a good tethering solution that doesn't involve rooting.
Many thanks for any help!
UPDATE:
Here's my promised update.
I contacted June Fabrics directly, and they promptly replied that I got a bad build of PdaNet, that was only on their download site for a few days. I downloaded a new version, and problem solved!
Of course in the meantime I did a clean install of XP, but at least I have a clean PC.
