Help Droid X won't go passed "Droid Triangle Screen"
sillar68
I took the stock GB OTA and it seems the battery is discharging faster than before the update.
I had read several people have done a factory reset and saw improvement in battery performance.
I've powered down and then restart using the power button and home key. when I get to the android triangle with the exclamation point in it like this: http://androidbloke.co.uk/wp-content/uploads/2010/05/image_thumb13.png, I push the search key and get no change. That screen shot remains the same. The only way I can restart is to take the battery out and then power it up.
How do I get to the screen to do a factory reset?
The process is a little different with GB, you need to press both volume buttons rather than the search button once the exclamation point comes up, the power button is now enter rather than the camera button.
And once I select "wipe data/factory reset," then I get the message "Data wipe complete," then I choose "reboot system now?" correct?
