Not sure if this tool can help you guys out or if you already know about it but it looks interesting.
Mercury - MWR Labs
Mercury allows you to:
Mercury - MWR Labs
- Interact with the 4 IPC endpoints - activities, broadcast receivers, content providers and services
- Use a proper shell that allows you to play with the underlying Linux OS from the point of view of an unprivileged application (you will be amazed at how much you can still see)
- Find information on installed packages with optional search filters to allow for better control
- Built-in commands that can check application attack vectors on installed applications
- Tools to upload and download files between the Android device and computer without using ADB (this means it can be done over the internet as well!)
- Create new modules to exploit your latest finding on Android, and playing with those that others have found
