Help Drop down Wifi Tab Unresponsive
intermittenly, my wifi button will not register my touch to turn on. I would have to either do a battery pull or power down to get it to work properly. it usually happens after a couple reconnects. i am not rooted running 2.3
Try putting the phone into airplane mode, then turn that mode off and quickly toggle the wifi button before the 3/4G connection kicks back in.
Also...how did you get 2.3 without being rooted?!
I had this same issue once or twice. All you need to do is turn it on through the settings then it the pull down will work after that.
