Drop phone calls
  • Thread starter Thread starter Maida519
  • Start date Start date
M
Maida519
Guest
Samsung galaxy SGH-I777 ATT- 1/2 yrs old. Drops calls as I am talking. There is no rhyme to reason and it does not do it all the time. as Im talking I've noticed sometimes the phone will be black from being dim and then start flashing a couple times then drop the call. sometimes I can call back and it is fine other times it will not let stay connected. I took my phone in and had it reset as new phone and it still does it. I am sure I am not hitting the off button and everyone I take it to says they run tests and its not showing anything. I love the phone other than this issue!
To make certain the off button has nothing to do with it, uncheck the "The power key ends calls" box in Settings in the phone app. Then again it could be an inermittent problem with the 2G radio, or an intermittent antenna contact. Have they checked those things?
Hey maida, welcome to our AndroidForums!
I think I'd take it back to the carrier / retailer and see if they'll give you another device--this one seems like it might have a hardware issue as Rukbat mentioned.
Best of luck!
