Help dropped calls
hi all i am getting a few of these well quite a lot actually putting up with them because i like the phone.
then yesterady (wed 280710) phone had a real hour or so dropped every call wouldnt connect to anything,but after plugging in charger and moving areas (not sure which one fixed the problem) things returned to normal,
actually managed to finish one long call yesterday afternoon thats a 1st i think.ayone else getting same problem or have i a duff handset :( thanks
like i said i l9ike the handset so putting up with it,was only really bad for about a hour dont think it dropped one call yesterday mind u didnt make many.
if it just the odd call will put up with it but if it get worse will go back to them :)
mines not dropped a single call in the month i've had it. it shouldn't drop any unless you're going through an area where there is a very weak signal
