Paraflier
Anyone else's Bionic acting uppity??
Starting today, my Bionic has taken to dropping ALL signal periodically. (not just data, but the entire signal strength indicator is the dark grey, no bars) Then the Light Grey 3G hangs on for a bit then Light Grey 4G, then it locks in blue.
Also when using the web, I will navigate to a page, but get redirected to a different page.
I have "GPS Status" an add-on app I use for the 'radar' function that now suddenly fires up and runs in the background and it never has before. And I have had this app forever....
Almost sounds like a virus. I have Lookout, but from what I an tell, it is mostly for your apps.
Any definitive way to tell what the heck is going on? I have had ZERO troubles since the ICS upgrade till today.
If there is some malware, or a virus, would an FDR take care of it?
