Root DSP Manager
McCookie
Anyone know how to get DSP manager working or any other similar program? Since the stock Miui sound enhancer is too basic to be honest.
I've tried to just install the apk of dsp manager but it doesn't seem to affect the sound coming out my phone/headphones.
Thanks in advance,
McCookie.
I'm not sure DSP Manager works with MIUI? Could be totally wrong though.
Are you just using a file manager to install? You might need to manually install using Terminal Emulator or Root Explorer (DSP Manager could be classed as a system app and would need to be installed on the system partition).
The root explorer method is probably easiest, the instructions are here: http://androidforums.com/droid-all-...ling-apk-system-app-directory.html#post580115
Yep worked :D thank you very much :D , never knew I had to do something like that :P.
