maximumhax
Ok, I had an idea. The app boot manager allows some phones to boot multiple roms. My take of this is that it installs the roms on SD cards in their own folder, modifies your original boot.img to boot the rom on the SD card in foobar directory. Then if you want to boot another rom, it modifies your original boot.img again and flashes it to your phone so when you boot up it boots the modified boot.img to boot from the SD card.
Triumph can't use this boot manager app because our boot.img can only be replaced in "download mode" (VOL DOWN + PWR) and replace the boot.img and reboot again. The app "boot manager" can't do this. So my idea was that there is the ideos x6 touch recovery menu that allows you to select Stock recovery, CWM recovery touch, reboot, and shutdown.. which the touch recovery boots and some things work, but flashing a rom doesn't work for me.. anyways back on track..
Why not have an app that we copy our boot.img into sd card manually.. let an app modify it.. and we rename it boot-rom1.img ... boot-rom2.img.. etc.. then copy all the boot.img's to the boot loader manually.. and have a custom recovery where you can select.. CWMk recovery, rom1, rom2, rom3, reboot, etc..?? if you select rom1 then boot phone normally using boot.img...
if you select rom2 use boot-rom2.img that you already placed manually in boot loader..
now obviously the setting up part would be all manual, but after it's setup I could boot CM9, CM7 just by rebooting into recovery and selecting rom2 or rom1 etc...
