I've been trying with all my might but can't get it to work. The essential requirements are 256MB free for the game (our full RAM) and 800Mhz (we have 600). The closest I got was installing Velocity0.3 because it uses less RAM, then adding GetItNowMarketing's older Turbo kernel that supports both overclocking AND using a swap partition (for the mhz and ram requirements), and then installing the non-kernel version of Turbo4 for the JIT compiler, which makes the most difference in performance. Then I used SetCPU to turn up the processor (I could only get 729Mhz without overheating, ymmv) and Swapper 2 to set up swap.
When I try opening it without swap it just closes immediately, so with swap I was able to at least get it running and play it a bit, but it was impossibly slow and uneven. Overclocking didn't make a difference, and I don't think I ever tried it without JIT.
So I give up, I'm getting the PC version when it comes out, if it supports playing online with my girlfriend who got a Galaxy S. The only way I can cope with the crushing weight of defeat is how crazy smooth my Ally is otherwise, and how flawlessly it plays my other games, like Raging Thunder 2, Heavy Gunner, and Fruit Ninja.
