Help Duplicate contacts removal question
ohioboy
Just received my Incredible last night and already have 2 sets of contacts. One from Google (gmail) and one from the backup assistant. They have you download those on the backup assistant when setting up the phone.
I would like to delete the backup assistant ones and use the Google ones. How would I go about that?
Thanks for your help!
You don't really need to delete them, you just need to "link" them. Under people, click on the contact, upper right corner there's the link icon, click on all contacts and find the duplicate entry for the same contact, either phone or gmail. It will merge the two while keep unique info between the two entries.
Hope that helps.
I have over 500 of them. Is there a way to do them in mass?
Ok I had like a dozen of one contact in my phone book. (something that started when I had my Moto Q) So I figured I'd try linking them. I chose the first on the page (since the whole page was just the same person listed over and over) in the contact page I tapped on the link symbol had a little 5 over it. It gave me a whole list of the same person with little broken link icons. I tapped on the broken link to link them together. Then I linked all of those saved backed out to the contact list again and then went back in. Took like 3 times but it was faster than I thought it would be since it will do more than just one link at a time.
