Dust in camera
jcalow
Does anyone know of a way to remove the external lens cover on a Desire HD? It seems to have a bit of movement in it, which would suggust it may be removable. Mine seems to be completely full of dust and this is causing terrible problems with the picture quality.
Many thanks in advance,
Josh Calow
Desire HD, not sure its possible as its in the unibody - I had this problem with my Desire and I just took the back off, but with the desire HD I'm not sure you could do it yourself.
