Root Dust in Screen
kadams161
Hello, I understand that this isn't all about rooting but i have a lotttt of dust under my screen and it keeps coming in. If i send it in for repair will they care if i'm S-off and on a custom rom? if so how do i go back to total stock? \
THANKS
THANKS
Try sucking / blowing into the Headphone Jack (No Saliva though) :p
Yea i tried that and nothing happens unfortunately. There's a lot of dust and especially shows in the sun!! its very annoying and i don't think i can get rid of it by myself! the only thing is if it was under my screen protector but i don't think that is possible. The same thing happened to my triumph, i must have bad luck with dust :mad:
try it with any openings or slits i got rid Dust with the Triumph that way........... I can't say if it'll work with the Vvo but its worth a shot (tapping the screen may help but make sure to be gentle)
If it really bugs you that badly you can just get a replacement. They won't care if it's S-off'd or anything. Just don't mention anything about root and that sort when you call them for a replacement.
