One thing I noticed on the 2 E3D's I looked at is that there seems to be a small issue with dust being stuck under the screen right out of the box. Also, after removing the temporary plastic film that covers the screen, if you angle it in the sun just right, you'll notice small specks on the surface that can't be wiped away. There was also a bunch of dust under the temporary plastic film protector which wasn't very confidence-inspiring. Just an FYI to those who are planning on buying this phone...be sure to inspect the screen in the sun before purchase.
) i will have to ignore it...
