I have noticed some dust under the screen in the upper left corner. I have had a silicone cover on the phone since I bought it. How is the dust getting there and can it be removed? Huawei Ascend M860 Cricket
Even better question, us it distance or sweat? Sweat looks white and spotty. If it is an issue any cell repair shop can lift and clean under the screen.
It is dust. And it is under the glass not the screen protector. I have no screen protector on the phone. Its not noticeable unless the phone is off and in sunlight.
Well if that's the case then I'm willng to bet the rubber gasket has failed.
Imo the best thing you can do is take it to a shop you trust and have it checked and cleaned.
