If you are looking to use an app and a website like JustinTV to broadcast from your DX then the answer is yes (I have done it). If you are wanting to use it as a webcam for a video chat then this will be a little more difficult since there is not a front facing camera.
IP webcam crashes on some videochat programs with the Droidx or any of the droid family. To fix the crashes you have to set IP webcam to use a lower resolution but on droids, the resolution is fixed on one setting.
