Help dx camcorder problem/crash
westside
Member
I've had my dx for a couple weeks now and have an intermitent camcorder problem. Sometimes I go to make a video press record and the app crashes and so far the only way to recover is a reboot by which time I miss whatever I was trying to record. Very anoying. Is this a known problem? Is the a faster way to recover?
I'm having the same problem you're not alone.
Happening on HD with me as well.
Are you rooted?
EDIT:
I've read a bit and found one case where turning off geolocation off solved it.
And another where they thought it was related to Pandora, which might be the case in my case.
Make sure the vid camera works, start pandora, pause then see if the vid cam exits to home when the record button is pushed. Mine does it 100%, but to soon to tell.
