Root DX tether to PC to PS3 help
jr1125
Need help.
Wanted to test how good the connection would be if i tether my laptop from DX and wire connect to the ps3.
i did the stuff but on ps3 it keeps timing out during IP check.. any help?
also i have testher via wireless tether app but playing black ops online it is ALWAYS logging me off of psn saying it was disconnected.
I had simalar issues for xbox live. first you need to make sure you have the latest wifi hotspot for root users installed. This version is alot faster i think. Also you need to install the data throttleing hack. There is info in this forum somewhere or just google it. I works great. Then while you play stay plugged into a charger and set your phone where the screen never sleeps so you will continuously sync data. It will not be perfect but it is alot better than nothing. My phone on xbox runs better than some of my friends with dsl no lie. You will never host a game because verizons Nat settings suck but you can play with no lag to minimal lag. Good luck let me know if it works.
i ahve the latest. im on newest rubix as well. and downloaded the wifi hack zip. reboot recovery and installed from sd.
