Help DX2 Crashing
bluethunder
Anyone else having problems with their DX2 crashing and rebooting daily? Mine crashes 1-2 times a day. Sometimes out of no where when it is just sitting there, and other when it is in the dock.
Anyone figure out how to fix this?
I am so unimpressed with this phone, and its bugs. Unless Google does something radical with Motorola, I will NOT buy another phone produced by them. I will go to Samsung or back to HTC.
Is your phone rooted? What apps have you installed?
Have you tried uninstalling all the apps you have installed rebooted and started to re add them one and at time after waiting enough time between to isolate the culprit.
I have had this phone for tw weeks, came from a Blackberryand i could not be more impressed by it, its abilities and its stabilities.
If you have Lookout Mobile Security downloaded, you might want to try there first. Lookout killed my X - without it my phone is smooth as butter.
I have an X2. The only issues I've had are certain websites crashing the browser. never has the whole phone crash yet though.
no Lookout though.
I've had the x2 for almost two months now and it crashes at least once a day. The only thing i've found that helps is backing up my personal data and restoring the phone (erasing everything) and that usually works. But no matter what apps i download or what websites i visit it always starts doing it again. And it has made me re-think buying exclusively from Motorola.
Yep. Mine crashes once or twice daily too. Usually when I have it plugged in and playing audio or video but it's not limited to those. Didn't think I was was the only one but thanks for verifying my suspicions.
