Wolfedude88
Android Expert
I had to .sbf last night back to 2.1, rooted with Universal Androot and then used rom manger to update to 2.2 which is 2.3.9 then when I try to restore a backup or apply any zips from sd card during clockwork Mod recovery I get the following error.
ClockworkMod Recovery v2.5.0.5
E: Can't mount /dev/block/mmcblk0 (or /dev/block/mmcblk0pt1)
(Device or resource busy)
Can't mount /sdcard
Does anyone have any solutions to help me out? I am not sure if it was something to do with the root method I used or something else I need to do to get it going.
The first time I rooted I installed the first leak 2.2 myself and then rooted with adb, but I no longer have the leak 2.2 file so I rooted 2.1 first then installed 2.2 like I said earlier through rom manager.
Can't mount /sdcard
