Help e mails not sending
Any one else have a problem with e mails getting stuck in your outbox? Mine done it yesterday and now today. It kinda seems like once the battery gets below 50 percent it dont send them. Any one know how to adjust settings or keep this from happening.
Easy fix, go to settings applications then look for your email app open it and clear the data and cashe and that should work again or just to make sure after you do that turn off the phone and then turn it back on...email should be working fine again.
