Unfortunately not the case. I went through at least 6 pairs of headphones w/mic before I found a set that actually worked. You could always get sound, but the mic would not work.
I guess you'll have to do your own trial and error.
<M>
<M>
i dont think that is right!
I can use any standard headphone w/mic and works just fine. Cheap ones to expensive ones. at dollar stores crap to top brands.
I guess I got lucky and found some on the first try. These work great. Amazing sound, too.
NEW V-Moda Vibe Duo Gunmetal Rouge iPhone earphones - eBay (item 230461155528 end time Jul-10-10 19:39:56 PDT)![]()
V-Moda is definitely a sleeper brand for earbuds!I absolutely love the V-Moda Vibes! It's so odd that so many people have a love/hate relationship with them: "Too much bass", "not enough bass", etc. With these, it's all about getting them to fit properly for the best sound. I'm not one to give much credence to "breaking in" speakers, but these buds definitely do need breaking in for the best sound.
Also, these are wired for iPhone which means they will work properly with the Hero as both use the same pinout. So, anything designated as compatible with iPhone should work with the Hero.
I actually have the Vibes and the Duo and the Duo definitely tone down the bass, and sound better, overall. The Vibes are fun when mowing the lawn, though!
I think I have the same pair. Cost about $35? The mic doesn't work but the sound is great.I know, seems crazy. I plugged in some Sony's straight from BestBuy, got the icon up top with the mic showing, and nothing. Same thing with other brands that same day.
Plugged in the stock mic and headphones from my wife's Moment, and it worked just fine.
<M>
The issue with iPhone earbuds is the shape of the plug. Many iPhone-compatible earbuds have a plug with a fairly wide base that prevents it from fully seating in the Hero's socket, which is located on a curved part of the phone. You get sound but no mic function. I found one at Walmart for about $10 that fully seats but unfortunately I'm away from home and don't have access to the packaging that would remind me of the brand. I'll post again when I get home in a few weeks.
