Help Earphones problem
slashur
Hello
Please help I bought Samsung Galaxy W and it's great .
But when i tried playing songs through the earphones i can hear the music but the singer (lyrics) are are washed up and noisy .
My brother also faced this issue on his Samsung Galaxy Fit .
P.S : I'm using the original earphones which came with the mobile
Does this happen with ALL the headphones you use?
If it works well with other headphones, it might just be bad 'phones
If you get the same issue with all headphones, it could be the headphone jack or the application
To see if it's the app, try this
Applications > Settings > Applications > "All" tab
Find the Music player app and tap on it and tap on "Clear Data"
If that doesn't work and it happens with all headphones, then you have a messed up headphone jack
