Help Easiest way to remove the crapware?
jareth
Member
So my phone is running 2.2 and is rooted. I'm a bit of a newb when it comes to this; what's the simplest way to remove the crapware, now that I can. Is there an app, or is it a more messy hands-on process?
Either way, I can't wait to flush VZnav and City ID down the toilet they clawed their way out of ;)
I purchased "Root Explorer" from the app store. If you have root it allows you to mount the /system/app/ folder as R/W and then you can delete stuff until your hearts content or at least until you delete something important. :)
I have it, but won't their icons still clutter my app tray?
Is there a cleaner way? Like some sort of root uninstaller app?
No, if you delete the app, it should remove it from the app tray. You could also move the apps to a backup folder, but if you never ever want to use them, deleting them is fine.
Installing a rom is even easier than rooting, just download rom manager from the market, and select the virtuous rom, if you are coming from stock 2.2 you probably can get away with not wiping your data BUT DO A BACKUP! And make sure you have about 1gb free on your sdcard
Rom manager? Virtuous Rom? Damn..don't even know how to back up! :eek: That is lame.... Wouldn't mind finding a reputable local service to do this without violating the warranty. Besides, how would this work with the inevitable hot fixes & more soon to come out?
Haha, no. A new rom is a bit excessive. I think I'll just remove the .apk and hope for the best. Its a shame no "root uninstaller" program exists. Its times like this I wish I knew how to program; I feel like this is a huge niche waiting to be filled.
If you're rooted you have probably installed Titanium Backup. You can use that to "freeze" or permanently remove bloatware apps. Permanently removing them can make things complicated if you should need to unroot (eg for a warranty return), and there's always the risk of removing something essential, so freezing is a better option, at least at first, and especially since you're new to rooting. If you do remove anything, BE SURE to make a nandroid first, so you can revert to stock if needed! Another option (already described) is to move the bloatware so it won't run.
However, I second the recommendation to just install Virtuous. :) (ROM Manager is an app available in the Market, that makes it easy to download and flash ROMs. Virtuous can be installed using the free version. It's about the same difficulty level as rooting, or a little less, so do a bit of reading first.)
Titanium Backup is the easiest way. You have to pay to get the freeze ability. I just backed up my bloatware then uninstall it.
I didn't think backing up bloatware with Titanium will help you get it back, since it's part of the ROM (I tried after thoughtlessly deleting CityID). Somebody please correct me if that's wrong.
Ok guys, im new to the forums, and new to Android, but i've got a 2.1 Desire, rooted, and i've got the SDK (and ADB) installed on my PC.
My goal was to remove CityID for good, not just until the phone was rebooted, and finally got this to work. The end result was that i was able to remove not only CityID, but Twitter and all the other stuff i'll never use. Gone from Apps Drawer, gone from Uninstall screen, gone after reboot :-D
This involves ADB IN RECOVERY MODE, which many posts made out to be extremely difficult to get the timing right, special SD cards, a bunch of voodoo and magic, blah blah... I got recovery mode on my phone simply by typing
ADB REBOOT RECOVERY
then i had to mount /system (using Clockwork Mod on the phone, tho suppose it could be done via ADB), and was able to simply "rm CityID.apk", and even after rebooting the phone, it's still gone, no trace of it.
Whole process took about 2 min, and was very easy... no "rapidly inserting and removing the memory card", no cooking live animals in a vat of boiling water while chanting in latin, or any other nonsense.
Furthermore getting the phone into ADB recovery has worked flawless each time i've tried it. If this is something new, please respond and i'll be happy to write up a more detailed description.
