This seems to be the most simple and easy way to root that I have seen. Not sure if this gives you s-off or puts custom recovery. If you try please make sure you let everyone know.
Looks like it is used similarly to unrevoked so can't be easier than that. Also looks like it only achieves root, not recovery so not as good as unrevoked....
Don't see the point really, unless you never want to flash anything or use a2sd. Unless it does flash recovery of course.
If it does all unrevoked does, but on 2.3 it could be good..... but I ain't testing
