will it wipe out all my apps?
also do i need to go to 1.32 to update?
As said you will need to downgrade. The rooting process doesnt wipe apps however downgrading might...
Go here:
19/Nov r14: VISIONary + one click root - Android @ MoDaCo
This is for FroYo however if you have upgraded to GB let me know and I'll get a Gingerbreak guide up.
That said just a little look at the top of the screen would have revealed this:http://androidforums.com/desire-hd-...iversal-root-visionary-method-theunlockr.html
thanks .I Have upgraded to GB, any Idea how i can root it now?? never done rooting it would be nice if it explain step by stepthanks .
I tried downgrading from 2.36 to 1.32 using the method above. It got all the way to the bootloader but nothing happened from there. Rebooted and checked version number and I'm still on 2.36
Tried process again and when entering the command ./data/local/tmp/GingerBreak i get the error 'cannot copy boomsh : Permission denied'
I figured I'd try on here to see if anyone has encountered this before and knows of a solution before I have to register on the other forum and hope I get a reply on there.
Apologies if this is a daft question, i'm totally new to all this
