Accessories Easily removable case
superlou
I was wondering if anyone had recommendations on an easily removable case for the Atrix? The car dock is great, but even with the dock spacer removed, it doesn't proper latch an Incipio feather case (the thinnest I could get my hands on).
Since I can't find a case that will fit the car dock right, I'm going to go about this the other way. Does anyone have favorite cases that remove from the phone easily? I've read that some of the ones that fit tightly are really difficult to remove. I'd rate the feather case as moderate (around 20 seconds being careful). I don't mind a bulkier case if it's easily removed/applied.
Would welcome any suggestions/comments/tips.
Thanks,
Louis
Glad to know the feather can withstand repeated removal. At this point, I'm actually leaning more towards a beefier case since I normally store it in the same pocket as my keys. The feather was hopefully a compromise to avoid removal from the case for docking. I may stick it out with my fleamarket leather pouch for a while until someone comes out with a flip open pouch.
