I got Kurio 4s and within a month of having it. I got a google update that came with google play store. Just check your updates on your Kurio 4s to see you got that update.
Okay, I got the Google play on the Kurio touch in the update but how do I purchase and download games and music? There isn't an icon? This is the most frustrating device I've ever purchased and I bought it for my 8 year old because it was supposedly the most "user friendly".
You have to go to their web site and put the firm wear update first. Then after you follow the directions on installing it. After that you will have a pop-up once everything is done says google play update. It's a big file so you have two separate updates. after that everything is good to go. Good luck!
