Help EasyTether issues
khaos
I installed easy tether and it seems to work well... when it works. it keeps popping up "connection dropped" "connection established" over and over....
any thoughts as to why/how to fix?
i had the same problem. i looked everywhere but cant find the exact reason. my solution was to keep adjusting the way it connects when you tether it. my settings are.. i keep it as a disk drive. also very important... :eek: go to accounts and sync in the homescreen menu/settings. disable backround data. i do this while im tethered and i can keep it up with no disconnects for 2 days or more. using easy tether pro
