Hey gang,
I'm a simple business user with a dozen apps or a little better. Not a major power user. I need the basics to work smoothly and not a ton more, though "move to SD" would sure be nice as would bluetooth "voice command" operation.
I've been lurking since October and have scrutinized most every thread including the EC05 threads. I just can't seem to find a definitive answer. As near as I can tell, it seems more trouble than it's worth to accept the upgrade. If it ain't broke, don't fix it kind of a thing. But I'm not sure whether or not it's just a case of a few loud voices.
Would you agree? Or would you say that there is a fix for most of the issues that people are having and Froyo is just so awesome that I'd be crazy not to allow the OTA upgrade to install?
