Edge Panels & Apps (links included)
Augmented Edge (Note)
Needs Augmented SmartWatch Pro APP to work BUT does not require an actual smartwatch.
Settings to make the edge display work without a smartwatch:
Note Edge Options > Enable Note Edge > on
Note Edge Options > Only show if plugged in > off
Force Use Accessibility > off
Auto Clear Notifications > on
Always Auto Clear > on
Optimized Notification Options > Auto Clear (Android 4.4) > on
Optimized Notification Options > SMS Monitoring > on (if you want SMS to show)
Always Send Notifications > off
Phone Options > Show Notifications on Phone > Disabled
Phone Options > Show on Phone even if Off > off
Advanced/Beta Options > Accessibility Start-Up Check > on
Advanced/Beta Options > Enable Auto-Start on Reboot > on
Other options are up to you, depending on what you want to display.
Please let me know if these instructions need to be amended.
EdgeBoard {3 panels}
added.
"Galaxy Apps" links seem to redirect now. So you will either need to search for "EdgeBoard" on the "Galaxy Apps" app on your phone or get the apk from here.
EdgeBoard description:
"Your Galaxy Edge dashboard, right at your fingertips - date/time, battery, running apps and favorites.
After installation you will see 3 new Edge panels: the main one, the one with only running tasks and the one with only favorites. Favorites are editable within the panel's configuration dialog.
Tap on date to bring up system date/time settings, tap on time to call for S Planner, tap on battery to see energy statistics. Tap on running apps icon or star icon to expand the list. Tap on any running or favorite app icon to switch to it.
You can select to use any one of 3 panels, all of them or in any combination. For example, if you only need running apps - you can deselect other 2 panels. Or you can select favorite panel and running apps panel and switch between them by swiping from left to right over the edge."
