Help Edges near screen higher on one side
denise1768
The left side is slightly higher than the right. The right is almost smooth from glass to edge, the the left is not.
Anyone else have this?
My right top is slightly raised, I can feel the edge of the glass if I reach too high to swipe open the notification window, it is smooth on the left.
Ditto here, completely flush all the way around. Does the raised edges impact the ability to put a case on? (curious) thanks.
Mine is nothing like that. I can't even "see" it, only noticed because I can feel the corner when*I swipe my thumb. Really can barely even notice it, I would say less than the thickness of a hair on mine. Only the right half of the top, all the rest perfectly flush.
Put it in a nice case and you'll never notice it ;):D
That's exactly what I'm doing. Purchased the same one you did except in black. I wanted the light pink glittery one (hate pink, but that pink looked nice), but it wasn't Amazon Prime and really need a case asap. Probably will get the pink one too if I like the black one. :)
I just saw another phone that was had the same raised left side.
mine are slightly raised all around. would love flat but I guess I can't get too picky when some don't even have theirs yet
