Help Edit Folder contents on Homescreen?
Maddingo
Member
Does anyone know a way to edit the contents of a Folder that you create as a widget on a Homescreen? I know you can edit the name by tapping and holding it but I want to delete some stuff i put in the folder. I tried locating the folder with Astro and could not find it on the phone memory or the storage card.
Thanks!
That's different from the Folder Widget. I have made folders the Astro way and placed shortcuts to specific files in there. That becomes an editable folder that I can find. The one created from the Widget I can't find.
Ahh yeah read it wrong sorry, I've found that you just hold down the thing you want to take out of the folder and drag it out. And it places it on the desktop.
See if this works for you
If you don't means this not sure what you do mean, sorry maybe make the original post a bit more clearer if i'm wrong. Or hopefully someone else can help you
That worked. I thought I tried that before and it removed the whole folder but it worked fine this time. Thanks.
