Help Edit volume of ringtones etc
peter7769
Hi
Does anyone know of an app for the phone that will allow me to edit the volume of mp3 ringtones, there are loads on the market but everyone i have tried fails!! Was hoping someone out there could recommend one that they use, just want to be able to up the volume on ringtones i download as some of them are to quiet ;)
Thanks
Pete
I use Zedge ringtones and most of them are blaringly loud. You can spend hours looking through them all. Plus they are free :)
Other than that I just use my own MP3 filed and use RingDroid as an app to create a ringtone.
Thanks, i also use zedge as well, but i really want to be able to control the level myself.
Pete
I use "Audacity" however its for the PC. Its free, and allows me to accurately set the trim ponits. It also allows for gain control.
Thanks but you are missing the point, i can do this no problem on my pc, but i want to be able to do it on the phone to save a lot of messing about.
Pete
