Apps edittext to edittext
06shana
,hi
im searching for possible answer but i only see edittext and textview ..
i want to ask how can i get the text in edittext1 on edittext2 when i clicked a button ..thnx ..
i try this code but it doesn't work ..
String ulname= txtlname.getText().toString();
String ufname= txtlname.getText().toString();
String ucourse= txtlname.getText().toString();
txtlnme & ulname and so on is a EditText
You need to post more code and the error message you are seeing.
There is nothing wrong with those lines as is, but I suspect you are misunderstanding variable scope.
