@jhrIII - You will not brick your phone coming from ED1 (Rooted). I updated just fine to EE4 from Rooted ED1. Also, The ROMs/Kernels such as PBJ and Gummy Charged 1.5 are all OPTIONAL. You DO NOT Need them to get EE4 Rooted. If you just want EE4 Rooted, then Go
HERE and pick up on Step 7.
@Outsider - Please don't get offended. I know you are trying to help out (I know, you helped me out a few days ago and I appreciate that), but if you are going to respond to someone's question, please be more clear in what you post. Here are a few suggestions on how to get that done:
1. Be more organized with your responses. Proper punctuation and use of nouns and verbs helps. (Odin is not a verb)
2. Outline your steps and separate them by using numbers and using different lines for each step. (Step 1 in one line, Step 2 on another line, and so on and so forth) A wall of text is never a good thing.
3. If you can, post direct links to downloads/instructions/sites. This reduces the amount of confusion that can occur bouncing from one site to the next.
4. Answer their question to the best of your ability. The OP didn't ask for Peanut Butter Jelly Time or Gummy Charged 1.5. (Actually I don't really know what the OP was asking, haha) But on another post
HERE, they asked how to "just root EE4" and nothing else. I'm glad that you love Custom ROMS/Kernels but that is something that you have chosen to do, and that is something that they might not want. And if they follow your guide, they might be unhappy with the results.
Just my $0.02.
