there are others to try the repository there is a CWM safe FF19 kernel
http://forum.xda-developers.com/showthread.php?t=1662295
Cool, Is that what you flashed your ROM with?
Thank you, but I don't see a FF19 kernel there?
I flashed my ROM with agats and had no problem but agats wouldn't work with the toggles
when you tried to flash the toggle were you on the the FK23 repack with AGAT?
I believe so. Says FK23-agat recovery tar
As I understand it FK23 recovery is having some issues. Hopefully those will be solved soon enough.
You can set so it uses the power button. Once in recovery scroll to the top then hit vol up, then vol down a couple of times, it will toggle the power button on and off that way.
Was an accidental find when watching a Qbking77 video, so credit goes to him, but it does work doing that.
Then you can use the power to pick your selection. That trick also puts a back to option on the screens as well, on the bottom.
i will try that thank youAs with the el29 cwm kernel you press the home button to select. .. power button goes back
very very nice i tried it and it works .. thank you so much.You can set so it uses the power button. Once in recovery scroll to the top then hit vol up, then vol down a couple of times, it will toggle the power button on and off that way.
Also I have used EL29 to make a nandroid, and also to put on toggles and switch between FI22 and FK23 roms and kernels and modems, so I know for a fact it does work.
very very nice i tried it and it works .. thank you so much.![]()
Okay, so I'm running stock rooted and would like to flash an OC kernel. I've looked at kris 41's because it has CWM Rwilco12's Android Repository I've also looked at Agat's 0.5.4 and 0.6.8. Any advice will be appreciated. Thanks.
The older kernels like EL26 or FF18 I would recommend those for using to flashing another ROM not for daily running. I was using the AGAT 0.6.8 with the FI27 modem when I was last running rooted stock. There are also repacked kernels with AGAT recovery too. I have the understanding that 3g and 4g performance is better with the repacked than with the source built
http://rwilco12.androidfilehost.com/?dir=Kernels/Recovery Kernels/ICS/Agats Recovery/ZIP
Codegerm
Codegerm
Yes you can use Agat 0.6.8 (using the agat kernel is the way one Roots the phone by using the pc). I also chose to flash the modem to FI27. yes you can use a repack kernel too. the main thing is to make sure you are selecting a touch wiz kernel for ICS if you are on Stock. I will say the AGAT 0.6.8 kernel does have nice voltage, clocking control features along with the pegasusq governor (an on demand with hit plugging for the second core to allow the phone to suspend the second core when not needed) that i set via an app like voltage control.
