Root Elite cm7 sources
LowEndGeek
Android Expert
Does ANYONE have a copy or access to the sources from the previous attempts at cm7? I'd like to use them at very least for a learning experience.
If you ever get CM7 working on Elite, I'd like to see CyanMobile ported over to the Elite. Used CyanMobile on a VirginMobile LG Optimus V and it was an awesome ROM.
I remember that one, if I did anything from the V it would probably be backside
As I don't know much about porting, 'backside' doesn't mean much to me. Reading your post on porting, thought this may be doable, i.e., porting CyanMobile to Optimus Elite.
it doesnt have a google sign in like cm9 n 10 n stock, only has corporate, play store gmail any thing google sign in app based that is, i like it tho, those things doesnt bother me atm, except wifi signal stuck on color grey for some reasom but it works other than that
Just flash gapps for cm7
ok gapps installed and it works now
oh i downloaded some themes, i switched to ics too see if the wifi signal turned blue, i wouldnt know where to start on modifying it lol
