Help Email not deleting.
  • Start date Start date
A
Android Question
Guest
Can't delete email's from my new Galaxy s6 edge,they delete but come back minutes later,any ideas please.
Is the email server using the POP3 protocol? If so then you probably need to enable the "delete from server" option in the account settings as a delee only acts on the local copy.
If using IMAP then mail remains on the remote server and a 'delete' should remove it immediately; anything else suggests a server-side problem that will require the attention of your email provider.
