Seems everything is set up as normal, but seems now email wont sync,,,and my data doesnt respond very well to commands from the phone, or it's very very slow....what can I do?
I did but thats not the same, i did not delete anything wrong... My data works with the web, but won't work with adding a gmail accout, or metroback up
It sounds exactly like the problem that the vast majority of Metro android users are experiencing since last Thursday. It is a known problem to them but they will not admit it unless you clue them in that you know about it. They are working to correct it. It has taken longer than it should, but likely has nothing to do with your phone.
