I couldnt find another place to post this.
Tablet info:
Ematic Eglide XL Pro internet tablet & HD video player
10" screen & Android
4gb built in flash
Android 4.0 OS
This is a friends tablet he bought without a charger so it Worked fine until low battery and it shut off. No charger so it sat for a month.
I have a charger so I charged it overnight.
Now With the charger connected it will turn on and flash Ematic splash screen for 1sec. and shut off.
With the charger disconnected it will turn on, show Ematic splash screen for 5sec., then it goes black with flashing cursor in upper left corner for a few seconds, then black screen with the text 'Android_' about 1/3 down on screen. It stays here until I power off.
I have tried a hard reset, wiped data, and even unplugged battery with no change.I am stuck at this point.
Is there a fix for this?
Do I need software/firmware and where do I get it?(Icant find it online)
If my only choice is to root and install something else I need a simple guide on how to and the software/firmware.
Tablet info:
4gb built in flash
Android 4.0 OS
