When placing a Password or Pin as the screen lock a Button appears on the screen called Emergency Call or something like that and it can't be removed. as a result of this button i have pocket called 911 several times, what would happen if i were to fail to notice that while in my pocket the display button got pressed and the emergency button as well, they would assume i was in danger and in need of help and would track the call and send a Officer, at Home or at work this could be rather annoying and luckily this has yet to happen though i am sure the police are rather annoyed with the countless pocket 911 calls. PLEASE for the love of god REMOVE the Emergency Call button or at least give the Option to not have it...for This reason Alone i will be buying a New Apple Phone because both my father and brother have one and don't have this STUPID Emergency Call button on there display. When you have a Pin set as the lock a Keypad shows up on the screen when you click the display button anyways(which i don't like either) so it would only be 3 buttons instead of 1 to press if you actually did need to call 911.
