Help Emergency Mode problem
M
Member420406
Guest
Hi,
I've had my phone a couple of weeks ago now and about 6 days ago I got a notification telling me a new version of software was available and to connect my phone to the PC Suite to update. So I installed all my USB drivers etc before the update but the program either wouldnt connect to the phone or repeatedly tells me that there is a problem with the connection between the comupter and cellphone and to disconnect the wire, remove and reinsert the battery and try again.
This still didn't work and now anytime I power off my phone, it gets stuck in emergency mode (yellow screem with white text saysin "emergency mode!!") when I try to turn it back on. The only way to get passed this is to remove the battery for about 15-25 minutes and then turn the phone on again and it powers up as normal. I have tried to do a factory reset via settings>Privacy, but the phone gets stuck in emergency mode when the phone reboots and all my data and settings remain intact.
Any suggestions on how I can fix this problem would be greatly appreciated.
Thank you very much. :)
my phone also like the, and I can restart the phone by hold the "home"+"search"+"volume down"+"power on",but I must do the every time
who can tell me how can I do?
Im having the same problem too.
I was trying different roms on my lg p500 and i wanted to restore back to my original rom because i was having problems with the other roms. So i restored through recovery, flashing to rom through the zip file but because i was having again problems with that rom i decided to again the original room but this time to flash through the KDZ software. I followed the tutorial and i don
Hi.
That is what i ended up doing it because i trying to solve it and end up doing worse and the phone died, not emergency mode, nothing, didn't turn on. Im waiting for the phone to get back from service.
Thank you for the help
