Help Emoji Problem
dword41
I haveq Samsung Galaxy Note 2for USCellular. I downloaded the go sms app and plugin but still can't see emoji. I also tried this with pansi and handsent. But no luck. Can anyone help me?
They only seem to work in Go SMS when they do work and right now none of them are. Maybe the emoji keyboard needs an update.
They work with me..i can send messages with emoji to my friends who have iphones they can see them and send them to me....
do you have these installed?
GO SMS PRO
GO SMS PRO EMOJI PLUGIN
trust me they will work :) see my text below.....from my GN2
now make sure to select the second android icon to see the emoji....highlighted below in blue at bottom of screen
Screenshot_2012-12-09-23-16-40 copy by Ceva321, on Flickr
@ceva~ Come here & let me kiss your forehead. :p
Yesterday when I posted my response it didn't dawn on me that I was using "stock" msg while talking in my head (and here) about Go SMS.
@dword~ double check you didn't make same mistake I made. Do you see the GO icon in the top right corner of the app?
Here is the problem I am having As of now. I will try hand sent
GO SMS PRO
I have them both installed I can Send but can't receive
ceva, you first and second are the exact opposite shown on my Go SMS screen. My first one is the default android emoji, and the second one is the iPhone ones. But even though your tab order is reverse of mine, the contents are the same. My 2nd tab has the same icons you have... very strange.
When I sent the emoji on the first tab, iphone sms will see the ascii smilies.
But if I sent the 2nd tab ones, they see the emoji.
