Open the app and hit menu, then go to setting. Under general remove check for
The link below has detailed instructions on how to turn off the yahoo app notifications .. worked perfectly for me!!
[Solved] Possible to disable notifications for Yahoo Mail on Android? - Security Answers
Problem is you will not get notified if you get a message in messenger, so whats the point? I mean this is almost like saying "turn the program off" .... don't get me wrong best solution we have but this type of "fix" in droid land is getting frustrating!
I have disabled background data and now " enable background data in settings" always appears in notification bar. It says yahoo applications needs it. Probably a result of installing yahoo mail app. Anyone know a work around to keep the message out of notification bar?
